1999 Z222 Shabah Helm Switch/es ID
Introductions
Old 06-12-2018, 02:46 PM   #1
Tomroth is currently offline
My Model: Z222 Shabah
My Engine: 5.7L Bravo I
Send Tomroth:
Default 1999 Z222 Shabah Helm Switch/es ID
Greetings and thanks for the add.
I recently purchased a 1999 Z222 Shabah. I looking for help to ID the helm switch/es, as age has worn the names off each one. I can figure out what most of them do by action or sound. However, most important to me is the HORN... I cannot get a "toot" from any switch push. I assume the horn is DOA. I'm wondering if the horn has a separate on/off toggle and/or a momentary push switch? Also, where should the actual "horn" be located/mounted? Right of the windshield or underneath the helm?
Any assistance someone could lend would be greatly appreciated.
Smooth sailing,
Tom Rothweiler
  • Old 06-13-2018, 06:32 AM   #2
    John822179 is currently offline
    My Model: Z225 Davanti
    My Engine: 5L FL V8
    Send John822179:
    Default Re: 1999 Z222 Shabah Helm Switch/es ID
    Hi Tom,
    I had problems with the Horn on my Z225.
    You should have a Stainless Grill on the Starboard side, just ahead of the windscreen.
    The Horn/s will be behind this.
    The switch on mine is on the far right of the instrument panel and is a Rocker with no light.
    My problem turned out to be a corroded connection in the multiway connector between the instrument panel and the hull wiring loom.
    In the end I replaced the existing cable with a new one running directly from the switch to the Horn.
    Hop this helps
    John822179
    Mariah Z225 5L V8
    Keep the dry side up
    Thank you John822179 for this useful post!
    Tomroth (06-13-2018)
    Old 06-14-2018, 12:08 AM   #3
    Try this... left to right; Horn, Blower, Stereo, Lights, Acc, Acc, Bilge, Acc.
    Old 06-14-2018, 12:51 PM   #4
    Send Tomroth:
    Thanks for your reply. I found the actual horn switch. On mine, it is to the left of the key switch (starter) and next to the blower switch. My problem, now, is that I cannot see the actual horn mech underneath or inside of the helm cluster. The oval grill on my starboard side, which I presume is the horn, does not appear to have an easy removal procedure. I was hoping that the grill would pop/pry off, thereby exposing mounting screws for the horn. So this is, really, my dilemma: how does that grill come off?
    Old 06-19-2018, 04:00 PM   #5
    dbolt is currently offline
    My Model: Z222 Sabah
    My Engine: 5.7L, Apla II
    Send dbolt:
    My 2000 Z222 is on the left side below steering wheel. Ignition switch blower and horn are all together
    Old 06-19-2018, 04:41 PM   #6
    My Engine: 5L FL V8
    Send John822179:
    Mmmmmm, sorry, mine has 8 screws holding it on!!
    Is there an access panel, maybe in the cabin area, the other side of the helm??
    John822179
    Mariah Z225 5L V8
    Old 06-22-2018, 02:26 AM   #7
    Check the back rest in the bow seat directly in front of the driver console. It usually lifts up to gain access to the backside of the console.
    1999 Mariah Z222 Shabah treyolney Original Mariah Talk 3 06-11-2018 09:32 PM
    1999 Mariah Z222 Shabah $14500 Ibanez5str Mariah Boats For Sale & Wanted 2 06-26-2013 02:07 AM
    1999 z222 doucas Original Mariah Talk 5 12-17-2011 03:02 AM
    Total Members: 18,525
    Total Threads: 12,958
    There are 115 users
