Ignition problem
Thanks for making this forum available. I am new the the forum and have a current issue I am trying to resolve. I have a 2000 Mariah Shaba 222 5.7 Bravo 3. I am having a problem with the ignition. When I turn the key on, the gauges all work and everything seems fine. I then try to start the boat. Nothing happens. I try a few times and it finally engages the starter and starts. It runs fine one it starts. I thought it was the ignition switch and replaced it but it is still doing the same thing. Would it be at the starter or shifter? Anyone have any suggestions?
Thanks. |
Re: Ignition problem
Welcome to the club! Several guys around here should be able to help, sorry I am just a shade mechanic. Did you check the wiring to the starter?
Sounds like a ground or solenoid problem to me.. Maybe hudson river steve will chime in, he seems to know a whole lot when it comes to troubleshooting motor issue's.
Did you test @ solenoid? 1998 shabah 180 5.7l 350 mag Bravo III |
Sent from my SM-G900V using Tapatalk |
Thanks for the suggestions on ignition problem. It was the slave solenoid and was an easy fix.
Yessir! Good job buddy!
| All times are GMT. The time now is 12:51 PM. |
