-   -   hello electrical problem (http://www.mariahownersclub.com/forum/introductions/10907-hello-electrical-problem.html)
megknowsall 06-29-2016 12:57 AM
hi there everybody , own a 1995 Z275 davanti and looking for where I can find a replacement circuit board that is up behind dash. it controls lights hour meter dash lights etc .in desperate need of info ,thank you
Firestone 06-30-2016 05:07 AM
Re: hello electrical problem
Might be a hard item to find. Did you do a search on the repair threads?
Brian Belcher 06-30-2016 08:11 PM
This is a stab in the dark....
I'd be willing to bet that the board you're searching for is not exclusive to Mariah. Try a broad search on web for all the functions of your old one.
Like already mentioned, search for boat graveyards. The only one I've found in Arkansas said Mariahs are not junked out. In other words, he didn't have any and never has.
Good luck. You may end up having to engineer it so as you don't use the board.
pllevine 07-12-2016 04:43 AM
Or electronics guys like me just repair/rebuild the pcb
1998 202 Shabah 5.0L Alpha 1
