-   -   Jubilee Electrical Problem (http://www.mariahownersclub.com/forum/introductions/10901-jubilee-electrical-problem.html)
Scleepy1 06-26-2016 12:05 AM
Jubilee electrical problem.
First time out with 1998 214. Was going fine when all at once I lost all power. Dash was dead. Boat didn't turn over. No gauges worked. Battery was new. Surprisingly, the trim worked fine and was able to raise it....to be towed. I'm thinking ignition. Not sure where fuse panel is.
Thanks!
Brian Belcher 06-26-2016 02:41 AM
Re: Jubilee & Owners Manual
Not trying to be a richard head but could you PLEASE start a new thread. It makes it difficult to track of who's problem is on what thread. I will tell you that either your main circuit breaker has tripped, of which I don't know where it is on your boat OR your key switch has gone bad.
Scleepy1 06-27-2016 05:52 PM
Turns out the problem was a 20 amp fuse. Took awhile to find fuses behind throttle mechanism. Not sure why it short out.
MariahMan 06-28-2016 02:49 AM
Re: Jubilee Electrical Problem
Split posts into new thread.
Brian Belcher 06-28-2016 03:13 AM
Now the problem and thankfully, the fix, can be found and seen on SEARCH.
Really glad you found it.
