Some toggle switches not working
Replaced ignition switch on z222 shabah. Now some of the toggle switches (horn, lights, depth finder) are not working. Blower, hatch, seat switches are working. Checked the fuses under the dash. All were good. No blown breakers either. What else can I check?
Re: Some toggle switches not working
Sounds like you may have to move some wires on switch. If bet you have them on the "Start" tab. Do you have a test light or ohm meter ? Check to see if the tab on the switch that you have them attached to is getting Batt voltage in the Run and ACC positions
| All times are GMT. The time now is 05:18 AM. |
