-   -   '96 Shabah 210 - Electrical Problems: Bilge and Blower (http://www.mariahownersclub.com/forum/introductions/10858-96-shabah-210-electrical-problems-bilge-blower.html)
tstraszewski 06-13-2016 06:01 PM
My blower and bilge pump stopped working on the same day. I removed both to test and they work. The fuses don’t seem to be blown. Any ideas?
Hunter12345 06-15-2016 11:16 AM
Re: '96 Shabah 210 - Electrical Problems: Bilge and Blower
Test for dc power at the switch, then eliminate connection points.
Test for continuity in the lines to see if theres a break in the wires, butt joint that may be corroded and stopping the flow.
Brian Belcher 06-16-2016 04:29 PM
Only adding to Hunter12345's post;
The neutral wire is as important. Make sure that the two motors grounds are good. The ground at the switch won't have any effect(affect?cant never remember)on function of the motors. It is for the light on the switch.
