-   -   218 Shabah water tank (http://www.mariahownersclub.com/forum/general-maintenance/9387-218-shabah-water-tank.html)
Johnbarbour18 06-01-2014 11:14 PM
Where is the freshwater tank located?
Johnbarbour18 06-01-2014 11:34 PM
Re: 218 Shabah water tank
Does anyone know where you add water to the freshwater tank?
ColoradoDiablo 06-02-2014 01:05 AM
Check out this link:
http://www.mariahownersclub.com/foru...er-supply.html
According to the 2001 brochure , the 218 does indeed come with a 5 gal tank(Check under the sink).
Which was a bladder tank. Yours was probably leaking and got removed. That seems to happen with them.
One of the cuddy boys will chime in soon.:wink_thumbup:
BTW: Welcome to MOC! :)
Johnbarbour18 06-02-2014 12:54 PM
Ok Thank you!! I did find a hose under the sink that connected to the pump on the sink. I also read on another thread that if there was not a stingless cap on the outside of the boat, then there is no holding tank. Thanks again for your help!!
ColoradoDiablo 06-02-2014 03:25 PM
Guys are using the flexible 5 gal water containers from the camping department @ Walmart for the replacement. :)
Johnbarbour18 06-03-2014 03:54 PM
Thank you Larry. Do you know where I can get a copy of that owners Manuel?
ColoradoDiablo 06-03-2014 04:52 PM
It and many more are available to "Contributing Members" John.
HERE is a link to the benefits.
If you decide to become a Contributing Member , HERE is the link to accomplish that.
