docking light
I have a 2000 Mariah jubilee z244 and the port side docking light is burnt out can any one tell me how to replace the bulb thanks
Re: docking light
Griffin,
When i replaced mine i took a broom handle and broke the bulb out as it has a lip it locks behind making it impossible to get out. i then ordered my new bulbs from NAPA (i would get the spot) as you can get a regular wide area also but they dont light up nearly as much. Now take off the back rubber bulb holder and shake the glass out, i took a little soapy water around the new bulbs and with the tapered back they slide right in. good luck!!!!!! |
Re: docking light
The lights are Barnegat QL32s.
You don't need to break the bulb. Remove the rubber boot from the back of the light after loosening the stainless steel clamp Pull the stainless steel reflector from the boot Spray a little WD40 at edges of bulb inside the rubber boot and squeeze the sides of the boot side to side , the bulb will come out. It is kinda a PITA but very doable. Bulbs are 7604 for Spot 7614 for Flood |
Re: docking light
So does the whole assembly come out the front or do I need to go in from under the seat to get to it? I took all the screws out from around it and it never budged, didn't want to get too mean with it until I knew for sure lol
Re: docking light
The bulb and rubber housing comes out from the back side (inside the hull). The reason it won't come out from the front is because it's sealed into the hull using a high grade marine adhesive that's meant to keep it mounted there. :)
Re: docking light
Sounds like I need to loose some weight then or get my son to do it lol I looked in there and was hoping it was the other way or maybe tie a come along on to my feet to get me out of there. OK thanks for the replies
| All times are GMT. The time now is 06:28 PM. |
