Steering wheel
Im trying to get the steering wheel off. Sounds super simple, right? I think it should be too. Problem is I removed the nut under the center cap. The wheel still does not come off though. Am I missing something?
I am thinking that the wheel hub is corroded to the steering stem- limiting me from removing the wheel. Do I need an odd tool? 04 SC21 |
Re: Steering wheel
It sounds like you might need a steering wheel puller. Most auto stores carry them, and some places may rent them for short-term use!
Re: Steering wheel
Never mind... A little bit of wiggling and taping managed to pop it off. Not to mention a little liquid wrench.
Corrosion was the culprit. |
Re: Steering wheel
Thanks for the response though!!!
| All times are GMT. The time now is 02:55 PM. |
