sea/air temp
can someone tell me where the sea/temp gauge gets its info from? is there a transducer somewhere.
thanks |
Re: sea/air temp
My 96 had a paddle wheel on the transom
Re: sea/air temp
Is there any way to adjust the read outs? Both my air and water temps are inaccurate.
Re: sea/air temp
I dont think that there is any way to adjust them. You can try giving the transducer a good cleaning as crud/fouling can affect the temp reading & affect how freely the paddle wheel works. The bearings in the paddlewheel are only designed to last about 5-8 yrs. The electronics are inside the transom carrier mount so it may be that age requires the unit be replaced.
Re: sea/air temp
If I recall correctly, I read something, somewhere, that there were adjusting rheostats on the back of printed circuit board of the display unit. I will do some hunting and chime back in if I find something.
Re: sea/air temp
Just found the post with the instructions on how to adjust you air/sea temp readings. Here is the link to the post.
http://www.mariahownersclub.com/foru...o.html#post728 Its in post seven of this thread. |
Re: sea/air temp
Thank you
Re: sea/air temp
i see my transducer/wheel is broken off anyone know if they are avialable?
Re: sea/air temp
The company is Airmar that makes your part. It should be ST63, that what I needed for my 95. Airmar Technology Corporation » The Leader in Ultrasonic Transducers and Sensing Technology, and you can down load their catalog. I managed to find one on Ebay NOS, for around 45 buck, think they might be 75ish new. Good Luck
| All times are GMT. The time now is 03:12 PM. |
