Fading Gelcoat
My boat is fading. Any ideas on products that I might can use to make the finish look better until I am able dollar wise to have it re-coated? I just bought it today. It looks fairly good but wanting it to shine. Help me PLEASE!!!
Re: Fading Gelcoat
Many of our members have used Meguiars Fiberglass Restoration kit with very positive results. I use it every year, and it works great. :wink_thumbup:
There's also something called Poly-Glow that appears to work, although I've never met someone who's actually used it on their Mariah before. |
Re: Fading Gelcoat
Look at eBay for a product called aqua buff 1000 or 2000 (finer grit) ..... Good stuff. Then search for a product called wenol (polish made in Germany) look for their pink (discontinued) polish. It wasn't a big seller, but is one of the finest polish you'll ever find. This stuff works on everything (metal, fiberglass, plastic, etc)
Re: Fading Gelcoat
Looks like they call it glanol polish now, made by wenol
Re: Fading Gelcoat
Depending on the water the boat was in, you may have to first remove the lime coating. I use Lime Away with a little water to first remove the calcium/lime deposits and then apply a good automotive type wax and a little elbow grease. Without first removing any deposits first the wax can not treat the paint.
If you have light oxidation, try a wax listed as a cleaner wax which when used will leave a little bit of the color on your applicator. I am the original owner of a 1995 Shabah 212Z which I have waxed 2 to three times a year from top to bottom. The gelcoat to this day is as close to new as the day I bought the boat.:) Gelcoat and paint do not have the protective properties of an automotive base/clear coat and must be waxed frequently. I hate to say that once the original shine is fading, conventional waxing can only bring back a little shine. Good Luck with your Mariah:wink_thumbup: |
Re: Fading Gelcoat
| All times are GMT. The time now is 05:27 PM. |
