1999 260MCC electrical questions
Hello All, I have a 1999 260MCC all of the sudden the toliet stopped flushing. I have looked all over the boat for fuses or circuit breakers and have only been able to find the ones that are in the mid birth closet, the engine compartment in front of the generator, the ones below the steering wheel and the circuit panel inside the cabin. Are there any others on the boat that anyone knows of? I have searched several hours all over for a breaker box or something but have not been able to find any other ones.
My second issue seems to be that the 3rd battery that supplies 12 volt power to the cabin lights is not charging when the generator is running. The other 2 are charging but not that 3rd one for some reason. I have checked all the battery connections and the isolator connections and they look fine. The one thing I did discover is that it has a Stat Power True Charge battery charger installed and that has not came on while the generator is running either. Any help would be greatly appriciated. Thanks, Spnky168 :confused: |
| All times are GMT. The time now is 04:45 PM. |
