garboard replacement /seal
94 Mariah Talari Out today and noticed taking on water, Not knowing for sure if the bellow was cracked etc.etc,etc. I decided to trailer my boat home to investigate(usually at dock) I dried the area around the drain plug , then noticed on the under side of the garboard a small drip form , them it kept dripping at a decent pace. dried it of agian and them same happened. Can I jsut dry off garboard , seal it, or should I remove it , then reseal ,if so with what ? T it seems like an easy fix I just want to do it right.....Thanks
Re: garboard replacement /seal
Garboard?
Definitions of "garboard" on the 'net:
Jim |
Hi mikkibtune,
I assume you've confirmed the water is leaking from the Garboard housing and not from the plug itself. If your not sure if it's the plug or the Garboard housing, wind a few lengths of Teflon tape around the plug and reinsert it and then re-check for leaks. If it is the Garboard housing, I suggest you try to remove it, clean the transom surface and Garboard housing with a good degreaser (remove any old sealant), re-coat the Garboard housing with a high quality marine sealant like 3M 5200 Polyurethane adhesive/sealant and reinstall it. Wipe away any excess sealant and use your finger to make a nice fillet around the housing. Hey SEMIJim, the brass plug on the back of the transoms is sometimes referred to as the Garboard plug.... WetWilly |
(I think I'll just call them "drain plug" and "drain plug housing" ;).) Jim |
Better than calling it a "Bung Hole", right Jim? ;) Oh geez, now I've done it... brace for the comments... :very_scared: WetWilly |
Thanks wet willy, and bung hole plug is fine by me:):):)
Too easy... :rolling_laugh: |
| All times are GMT. The time now is 04:07 PM. |
