-   -   Exhaust Blower Inop (http://www.mariahownersclub.com/forum/general-maintenance/2402-exhaust-blower-inop.html)
twospeed46 04-30-2009 01:36 AM
Exhaust Blower Inop
I Have two switches ,one marked Blower the other Exhaust Blower.The Blower Switch works ,question is where is the Exhaust Blower located, or is it part of the blower system,I also have four exhaust ports with the blower switch on air flows thru the aft two,can't get anything from the other two. Any idea's?
ShabahZ280 04-30-2009 07:46 PM
Re: Exhaust Blower Inop
Do you have any hoses routing to your vents? I've got two stainless vents on the back of mine, but the blower only uses the port side. The starboard side doesn't have anything connected to it. I have a spare blower and hose at home that I was going to hook up just to be on the safe side.
I've never heard of the exhaust blower. But there's probably a great reason for it to be there! I'm going to make a guess it's something to use while you're underway as a way to keep the exhaust fumes out of the rest of the boat, or maybe it's a lower speed setting on the existing blower?
Let us know what you find out!
