1997 Jubilee 214 Trim Control
I have a1997 Jubilee 214 and the trim switch on the throttle control only raises the trim and does not lower it. I have to physically lower it at the rear switch. Anyone know the part number or had had this issue with theirs? Thanks in advance!
Re: 1997 Jubilee 214 Trim Control
Its a common issue. Have you read the 'Troubleshooter' at the top of this section? Its an easy fix.
Thanks Mike! I'll check it out!
| All times are GMT. The time now is 10:33 AM. |
