best manual for Mariah 21 SC 1998
I have a Mariah 21 SC 1998
with a 5 ltr Mercury Marine engine I think the serial no. is OLO45852 What would be the best manual to purchase which would give me details and views of this engine along with service details |
Did you check in the manuals section of the forum? We should have what you need in there.
Colin, we have the manuals online. Since you are a contributor, you have access to them. We have the service and the engine manuals that you need. In the "Engine Maintenance & Repairs" section, click the blue section called "Service Repair & Operating Manuals", then click "Mercury Mercruiser".
Hi and thanks for your reply
The reason for needing exploded detail of engine is Whilst at sea travelling at a fair rate of knots smoke started coming from all over In my panic I cut the engine whilst still in gear I was rescued and am now back on my mooring I am unable to get engine out of gear. My initial investigation I could not smell any motors that could have burnt out and there is no sign of burnt out wiring up to now The engine manuals I am looking for are in relation to my Mariah 21SC with the following engine 5.0 LITRE THUNDERBOLT 5 IGNITION MerCruiser SPECIFICATIONS MODEL………………….MCM 5 0 LITRE SPARK PLUG…………..ACMR43LTS DISPLACEMENT………………..305 CID PLUG GAP……………………….0.045 CYL FIRING ORDER…….1-8-4-3-6-5-7-2 MAX W O T RPM………...44004800 IGNITION TIMING……...……..10º BTDC IDLE RPM IN NEUTRAL……..…..650 SPECIAL IGNITION TIMING REQUIRED ENGINE ROTATION…. (LH) left hand For fuel and oil requirements refer to Operation & Maintaince Manual MERCRUISER DIVISION OF MERCURY MARINE, STILLWATER , OK , U.S.A. SERIAL NUMBERS 0L045852 OL243071 0L119376 ENGINE SERIAL NUMBER TRANSOM SERIAL NUMBER DRIVE SERIAL NUMBER |
| All times are GMT. The time now is 01:02 PM. |
