-   -   Water pump for sink (http://www.mariahownersclub.com/forum/general-maintenance/1200-water-pump-sink.html)
[email protected] 05-29-2008 07:44 PM
Water pump for sink
Hello,
Just wondering if anyone would know why the water taps don't work on our Z308.
The fresh water tank is full and everything looks fine. I am not sure where to look.
Gil
Roger Butterfield 07-11-2008 01:47 AM
Hey Gil did you ever figure out what happened with your water taps by chance? I have a Z280 but I'm not getting any pressure; maybe a leak somewhere; not sure.
Roger
[email protected] 07-11-2008 11:54 AM
I wish! No the tank is full of clean water, so can't figure, might be a busted pump. I haven't had much time to look at it, but it will come. Let me know if and when you figure it out.
Sorry couldn't be more help.
Roger Butterfield 07-14-2008 02:49 PM
I just got mine up and running. Make sure the water pump breaker is in the on position and flip on the pump rocker switch (located just behind the galley sink on the right) and you should be able to hear the pump engage. If not, the pump itself is located in the engine compartment starbord side bottom (you will see some small clear hoses attached) and test for current in and out of the pump using a voltmeter. Replace if current is not coming out. But my problem was that I didn't realize there was another switch behind the galley sink that had to be turned on :-)
[email protected] 07-28-2008 07:28 PM
Easy as pie!
Thank you for the instructions! I would never have guessed that it was so easy dah! Turn the switch on and presto I have water!
travelmike123 03-23-2015 06:01 PM
Re: Water pump for sink
I have the same problem with my 212 DX deckboat. Pump comes on, tank is full, but no water comes out. Any suggestions?
