Z204 (1998) Fuses? Circuit Breakers?
General Maintenance
Old 04-03-2018, 10:10 PM   #1
GTSJK is currently offline
My Model: Z204 Jubilee
My Engine: 4.3L Alpha
Send GTSJK:
Default Z204 (1998) Fuses? Circuit Breakers?
Below my throttle handle on my 1998 Z204 is a panel that has (and forgive me if I am using the wrong terminology) what looks to be pop-out circuit breakers. Are there also fuses in the boat that can be accessed, or just these pop-outs? I want to make sure that when I was installing my ignition switch in the fall (or when it was acting up prior to that) that I did not potentially blow a fuse that could be the source of why my rotational dimmer switch / instrument cluster lights are no longer working.
I'm also wondering if I could have accidentally pulled the battery lead to the dimmer when installing the dimmer switch since the dimmer sits directly above the ignition switch - but that is a stretch I think because with the blades I would really need to do some yanking to get it off.
Comments? Thoughts?
  • Old 05-18-2019, 09:38 PM   #2
    NoGhost23 is currently offline
    Status: Silver Contributor
    My Model: 202
    My Engine: 5.7
    Send NoGhost23:
    Default Re: Z204 (1998) Fuses? Circuit Breakers?
    if it is still relevant I have found a bank of inline fuses in the engine compartment. there are 4 leads 2 have the same gauge about 16-18 and the others are a bit thicker. I think they are the main lines to a sub fuse box under the driver console.
    previous owner left a broken fuse in one of them and am trying to find out the rating to repair it but I hope it brings the radio and other bits back to life.
    Old 07-25-2019, 07:58 PM   #3
    Unknownmariah is currently offline
    My Engine: 350 magnum
    Send Unknownmariah:
    any luck in finding the fuse ampage?
    1994 Talari 350 Magnum
    Z204 Ignition Switch 1998 GTSJK General Maintenance 9 06-06-2021 02:29 AM
    1998 Z204 Dimmer Switch GTSJK General Maintenance 3 08-29-2018 02:44 AM
    1999 Jubilee Z204 Jubilee Original Mariah Talk 1 09-15-2016 02:31 PM
    breakers how to read amps pppub Projects 1 04-11-2010 06:27 AM
    circuit breakers adornare Original Mariah Talk 3 06-12-2008 07:00 PM
    Total Members: 18,520
    Total Threads: 12,955
    There are 131 users
