New linear actuators
So I bought two new actuators to lift the engine hatch but I can't use the stock brackets. What do you guys think about mounting them per the below pictures? The bracket on left is stock one and bracket on right is the where new one would be drilled. I'm worried about the strength of the fiberglass. https://uploads.tapatalk-cdn.com/201...6a5ac0d67d.jpg
Sent from my SM-G950U using Tapatalk |
Re: New linear actuators
Does it seem "flimsy"? if so over time it could crack... If you can get under it from the side maybe try reinforcing it somehow with some creativity on your part.
| All times are GMT. The time now is 07:18 PM. |
