-   -   Rust stain removal on fiberglass? (http://www.mariahownersclub.com/forum/general-maintenance/11639-rust-stain-removal-fiberglass.html)
1996 Mariah Z252 07-14-2017 10:11 PM
Anyone know the best rust stain remover for fiberglass? https://uploads.tapatalk-cdn.com/201...ecc79fcb91.jpg
Firestone 07-14-2017 10:39 PM
Re: Rust stain removal on fiberglass?
Following
GaryDoug 07-14-2017 10:54 PM
This has always worked for me. With heavy stains, repeat the process several times. No effort is involved.
https://www.amazon.com/dp/B001229J7K...SIN=B001229J7K
You can get it almost anywhere including Walmart.
bigwhite66 08-22-2017 02:08 PM
If you haven't found a solution yet, I've been a fan of FSR. Was the only thing to get gas stains out of my hull. https://www.amazon.com/Davis-Instrum...1&keywords=fsr
1999MariahZ252 11-26-2018 01:22 AM
wow. seems you have the same things mine has lol
elrack 12-04-2018 11:04 AM
Muriatic acid should work.
Billyh79 12-15-2018 07:03 PM
I’m no boater I just got my first boat but I do own a body shop and I would try 2000grt and 3000grt wet sand paper and buff with 3m or wizards compound . Even triple 000 steal wool and compound .
