Lost
I need a wiring diagram for the light switch for my Mariah Shabah 1996 could anyone please help me....
I bought a new light switch. To replace the old one. And I can not get the new one to work. I feel like it's becouse I haven't got the right wires on the right pins . help....lol....chris |
Re: Lost
Hello Chris. What model do you have? There are wire harness diagrams for contributing members, but I am not sure that is what you are looking for.
Sent from my SM-G900V using Tapatalk |
Re: Lost
Do you have a digital multimeter? You can ohm out the switch to find the Normally Open and Common terminal on the switch. When you throw the switch on, it should show close to 0 Ohms. When you turn the switch off, the meter should go to infinite resistance. Then, find the wire from the 12VDC supply and plug it into the center (common) terminal on the switch. Plug the wire to the lights into the Normally Open terminal.... You're done, if you verified the ground to the light housing.
| All times are GMT. The time now is 04:06 PM. |
