-   -   Throttle gear release (http://www.mariahownersclub.com/forum/general-maintenance/11544-throttle-gear-release.html)
KCCHIEF 06-15-2017 02:28 AM
Ok new problem already . Finally got the 212 Shabah idling good . Now the push button on the throttle to release it from gear is not working at all . It won't click into gear now . Took the rubber cover off and plastic plunger is just free floating . I'm assuming it's spring loaded on the other side ? Also it looks like after market controller
1996 Mariah Z252 06-15-2017 02:30 AM
Re: Throttle gear release
Can you send a picture?
Thanks.
KCCHIEF 06-15-2017 02:38 AM
Thanks.
1996 Mariah Z252 06-15-2017 03:17 AM
Originally Posted by KCCHIEF (Post 62690)
I don't know if you ment to send a picture but it didn't show up.
KCCHIEF 06-15-2017 03:44 AM
Thanks.
https://uploads.tapatalk-cdn.com/201...701e35992e.jpg ("
KCCHIEF 06-15-2017 03:48 AM
Ok here it is
1996 Mariah Z252 06-15-2017 03:55 AM
Originally Posted by KCCHIEF (Post 62700)
Ok here it is
The spring inside must have wiggled itself out over time. It being after market.
1996 Mariah Z252 06-15-2017 03:56 AM
Looks like it's also made out of a basic plastic. Original mercruiser ones are shiney.
