-   -   Engine dies after 2 minutes (http://www.mariahownersclub.com/forum/general-maintenance/11383-engine-dies-after-2-minutes.html)
Unknownmariah 04-16-2017 09:32 PM
So in preparation for boating season i fired up my 94 Talari 350 magnum in my driveway and after about 5-10 minutes it shut off on its own. I had the ear muffs on with water coming out exhaust. Oil temp was low and oil pressure was low. Now it won't start unless I have a bit of throttle depressed and it dies after a couple of minutes. While it's running it sounds rough and weak. I already cleaned the carb and sprayed a bit of carb cleaner on throttle flap with no improvement. Any ideas? Could it be spark plugs?
GaryDoug 04-17-2017 01:35 AM
Re: Engine dies after 2 minutes
Check the fuel for water.
Unknownmariah 04-17-2017 01:43 AM
How do I do that? I'm assuming I take off the fuel filter? How would water have gotten in? The vent valve?
GaryDoug 04-17-2017 01:50 AM
This boat is new to me, so I can't give exact instructions. But you remove the fuel filter/separator and empty it into a jar so you can see if water settles to the bottom. It could be full and that would allow the water to get through to the engine. It could get in at the gas station/dock or any of a variety of ways. That's why there is a filter/separator. It's a good idea to replace it periodically.
Unknownmariah 04-17-2017 01:51 AM
Thanks! I'm doing that and picking up HEET tomorrow.
