front of cavitation plate broken off
General Maintenance
Old 05-03-2015, 01:48 AM   #1
dafucwuzat is currently offline
My Model: talari 221
My Engine: merc 5.7 b3
Send dafucwuzat:
Default front of cavitation plate broken off
97 bravo 3 -plate is broke pretty much flush with front of housing. didn't break into housing for a major problem but would like to fix it. reason its broke is trim limit blocks are shot. could i take it to a weld shop to repair? if so, is it cast aluminum? it also took the anode mount with it so that adds to the problem. whats the best solution for the trim limit after this is repaired also. thanks
  • Old 05-06-2015, 06:39 PM   #2
    Default Re: front of cavitation plate broken off
    Have a photo? It may be fixable but then again you may require a new leg...
    Old 05-07-2015, 12:20 PM   #3
    EricG's Avatar
    EricG is currently offline
    My Model: Z255 Shabah
    My Engine: 7.4l Bravo III
    Send EricG:
    I also have a 97 bravo3 on my z255 and it was almost completely broken last year. I had it welded and looks and works great. It cost me about $40 at a local welders shop.
    _________________
    1997 Z255 Shabah
    Old 05-07-2015, 08:45 PM   #4
    Send dafucwuzat:
    Did you change your trim stop setup. I have seen there is something with rear trim cylinder pin you can do. Just wondering cause I'm going to do it right just don't know what that is. Thanks for replys
    Old 05-08-2015, 01:17 AM   #5
    EricG's Avatar
    Send EricG:
    I didn't mess with anything. I assumed the previous owner hit something with it. I haven't had any issues with it.
    _________________
    1997 Z255 Shabah
    Old 08-16-2018, 07:32 PM   #6
    bloyet03 is currently offline
    Status: Silver Contributor
    My Year: 1196
    My Model: Z244
    My Engine: 350 MAG Bravo III
    Send bloyet03:
    I know this one is old but, I noticed this problem is EXACTLY what I'm dealing with right now. Anyone that has the trim limiter blocks still on their Bravo outdrives should contact their nearest marine dealer. There's a service bulletin from 99 that elmiinates these blocks and puts limiters inside the trim cylinders. That's what is currently being done on mine free of charge.
    Hopefully that little bit of info stops someone from having this happen to them as my blocks decided they no longer wanted to stay still.
    Old 08-16-2018, 08:18 PM   #7
    Send dafucwuzat:
    Did it brake the cavitation plate? If so, are they fixing drive also?
    Old 08-16-2018, 09:15 PM   #8
    My Year: 1196
    My Model: Z244
    Send bloyet03:
    Yes it broke my cavitation plate which i'm sure is why they had the service bulletin). No they're not fixing the cavitation plate. They wrote the service bulletin up as if there was a different problem. I'll try to post the bulletin up on here.
    Does anyone have a good link to where to check on what bulletins there might be on your boat?
    cavitation problem Nubs45 Original Mariah Talk 7 08-13-2013 11:59 PM
    Broken gas cap waynecochrane Original Mariah Talk 3 05-06-2013 06:47 PM
    Cavitation. akakman2001 Prop Talk 2 07-16-2012 06:24 PM
    Broken front seat 18.0 shabah (drivers) BobbyO Original Mariah Talk 5 02-04-2012 02:28 PM
    Wanted: Face Plate for Dash jarwiebe Mariah Parts For Sale & Wanted 1 07-04-2011 02:29 AM
    Total Members: 18,527
    Total Threads: 12,958
    There are 148 users
