-   -   Boat fuel capacity (http://www.mariahownersclub.com/forum/boating-101/7157-boat-fuel-capacity.html)
PCap 07-13-2012 11:33 PM
Boat fuel capacity
Can some one tell me or direct me where I can find the fuel tank capacity of the 1998 z302 number of gallons
mikeyt 07-14-2012 12:25 AM
Re: Boat fuel capacity
As a Platinum Contributor you have access to the Promotional Brochures in the Original Mariah section. Open up or download the 1998 brochure, find your boat & it will state your fuel capacity.
DCB_MINDED 07-17-2012 03:09 PM
Just past an arm and a leg.... not quite to the second arm. :D
Oregondunes 07-17-2012 03:46 PM
125+ gallons.
GregT 07-17-2012 06:35 PM
125 gallons! ouch! You either need to charge admission or take out a small loan to fill that puppy up! :eek_animated:
DCB_MINDED 07-18-2012 02:07 AM
My boat is advertised as holding 80 gallons, but I actually ran it out a few weekends ago (long story) and when I filled it up, It only held 70. I'm assuming because of the angle of the boat on the trailer, there was still air toward the front of the tank.
Oregondunes 07-18-2012 04:18 AM
thats why I typically run it to 1/4 tank, then put in 60 gallons at a time. not to mention, if you fill it up, your carrying all the weight around too.
dangel12 07-27-2012 12:28 AM
i actually just discovered mine today...i took the two screws out on a small panel right in front of the engine compartment and it lifted up to show the fuel tank and on there was a "plaque" that states the model number fuel capacity year built and all that jazz...mine however is only 30 gallons but from what i hear with everyone else having 80 or 125 gal im starting to feel better about that ha
