-   -   Navigation lights (http://www.mariahownersclub.com/forum/boating-101/5351-navigation-lights.html)
bethk 04-13-2011 06:45 PM
Navigation lights
Hi All,
I am new to this forum, just got my mariah jubliee 244 back in DEC 10 and the navigation lights don't seem to work. The manual isn't very clear exactly which switch is for the navvy lights but they don't turn on...and the stern light which is an automatic telescoping pole light does not come up either. Anyone have any suggestions?
Beth
Oregondunes 04-13-2011 08:41 PM
Re: Navigation lights
blown fuse.
run some power directly to the power light and see if you can "make it" go up and turn on. if not, then look for your lack of power source.
rajjneef 04-13-2011 09:38 PM
Assuming the jubilee has the same lighting switch as others then it will be a round rotary switch near the ignition switch. If turning either direction doesn't work then check the breaker, check to make sure the wiring is attached, then maybe check the switch itself. Those would be my first 3 areas to look at.
