-   -   drive problems (http://www.mariahownersclub.com/forum/boating-101/4034-drive-problems.html)
candanewell 05-09-2010 08:42 PM
drive problems
I took my recently purchased 1995, 202 out to the lake today and had a problem with the drive and I wanted to check if I was doing something wrong or if there is something wrong!!
Engine stated OK and I backed off the trailer. I positioned thetrim 'almost' fully down and engaged the drive to forward The boat started to rise and come on trim but then the forward motion stopped, but the engine rev's continued to climb, so I eased the throttle back,
The boat woudl idle OK with low rev's and even move forward with low rev's, but everytime I went to accelerate the boat would start to rise, but then lose forward momentum, but rev's increase,
Does anyone have any thoughts "hopefully" on what I am doing wrong or what may be the problem?
jgreen 05-10-2010 12:53 AM
Re: drive problems
Sounds to me like a bad hub in your prop. Try your spare prop or get one to try to see if that solves the problem.
IowaWing 05-10-2010 02:15 AM
Re: drive problems
Sounds like the hub has "spun" in the propeller and under load it now slips. I believe JGREEN has a good idea in trying another prop if you can find one.
candanewell 05-15-2010 08:35 PM
Re: drive problems
Hi Both,
took my prop in and looks like you guys were right and the hub has spun. just getting teh prop services now and hopefully next time out I can get some power going
Thanks fo rteh advice......Mariah Owner Club members are right again!
candanewell 06-01-2010 01:16 AM
Re: drive problems
Just wanted to say thanks again for the advice on this thread, we went out to the lake today and everything went great, lots of power and lots of fun.........
jgreen 06-01-2010 01:28 AM
Re: drive problems
Glad it worked out for you candanewell. Now keep an eye out for a good used spare prop, just in case. I always had the aluminum prop on board my old sea ray with a cheap prop wrench for emergencies. Lucky I never needed to change one out on the lake. Now, with the Bravo3 I can't afford a spare set of props.
mikeyt 06-01-2010 02:41 AM
Re: drive problems
:wink_thumbup:
