-   -   96 talari won’t plane out (http://www.mariahownersclub.com/forum/boating-101/13863-96-talari-won-t-plane-out.html)
Goldie 07-20-2021 07:10 PM
Hello all. Im a new boat owner and a new Mariah owner. I love the boat other than I can’t get it to plane out level unless I’m full throttle and turn a little bit. This boat is equipped with what I was told were planer boards!? A silver board with a cylinder hooked to them on each side in the rear. The first time I took the boat out they worked…kinda lol now I can’t get them to work at all…I can hear the white square relay clicking in the back but no movement. I honestly don’t know where to start. Any help would be greatly appreciated…I did search the forum before posting and didn’t see anything specifically pertaining to my issue
Kurt
mikeyt 07-20-2021 07:31 PM
Re: 96 talari won’t plane out
They're called 'trim tabs'. If you can hear the solenoid / relay clicking but nothing is happening you likely have either a poor connection (nut loose / corrosion etc) or the solenoid is failing / has failed. Check connections first.
Goldie 07-21-2021 12:43 AM
I would agreee with that. But I’m not sure which wires to start with…it’s a bit overwhelming when you look back there haha I would assume since it worked one day and not the next and the solenoid is clicking it’s just not getting a full 12v…thanks for your reply
