Freezing concerns @ 31 deg early morning
Boating 101
Old 04-24-2017, 10:52 PM   #1
SMain is currently offline
My Model: Z190 Talari
My Engine: 4.3 Mercruser
Send SMain:
Default Freezing concerns @ 31 deg early morning
I just bought my first boat last Saturday. Its a 1994 Z190 Talari with 4.3 Mercruiser. We lake tested the boat so its no longer winterized and we are keeping it outside while we are cleaning it top to bottom. The weather forecast show a couple overnight lows of 31-32 lows this week. Should I even worry about this , put a oil filled space heater under the cover or pull it inside my attached garage? I would have to move a bunch of stuff in the garage but its doable.
Thank you.
  • Old 04-24-2017, 11:09 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Freezing concerns @ 31 deg early morning
    Great question. I am a novice but would guess that you really need to keep the engine area above freezing
    John
    Old 04-25-2017, 01:33 AM   #3
    Send SMain:
    I just put it in the garage to be safe plus its supposed to rain 4 out of the next 5 day, that would put a damper on getting things done. Thanks for the response.
    Old 04-25-2017, 02:16 PM   #4
    My Model: Z202
    Send Firestone:
    Good call. Better to be safe than sorry.
    John
    Old 04-26-2017, 07:03 PM   #5
    chuse927 is currently offline
    Status: Silver Contributor
    My Model: 272z Barchetta
    My Engine: 7.4
    Send chuse927:
    Did you drain the block and water hoses? 31 probably ok if you drain the water.
    Sent from my SM-N920V using Tapatalk
    Old 07-08-2022, 02:01 AM   #6
    MR2NR's Avatar
    MR2NR is currently offline
    My Model: Barchetta Z
    My Engine: Reman Vortech 4.3 A 1
    Gallery Images: 7
    Send MR2NR:
    If its parked inside it should be fine. Never had water freeze on a 31 degree low. But the weatherman could be wrong
    Lake Powell trip from early July Motoxxx43 Trips, Travels, and Meet Ups 3 07-29-2013 12:50 AM
    Good Morning to all MOC members rhinoz Introductions 15 05-27-2013 08:29 PM
    Early Ice out Paul Z Chit Chat/Off-Topic 1 04-14-2009 10:56 PM
    Total Members: 18,525
    Total Threads: 12,958
    There are 239 users
